I have a 24VAC/60Hz solenoid. I used 12VDC just to try, and it worked good (well needless to say it worked as expected with 24VAC/60Hz).
What are the effects of a solenoid that's designed for AC running with DC? Applied force does not seem to be a problem in this case, so I think the main issue would be heat, as it is not running on the power source it was designed/optimized for. Technically speaking, what types of losses should be expected?
