I have designed and built the following 7-segment driving circuit utilising an Arduino Micro in order to try and further understand electronic circuit design:
When turning it on and applying a HIGH
voltage to the \$\text{LT}\$ and \$\text{BI}\$ inputs and a LOW
voltage to the \$\text{LE}\$ input, regardless of what BCD code I supply to the CD4511BE BCD to 7-segment display driver the LED display just flashes while displaying \$0\$. If I set the \$\text{LE}\$ input to HIGH
then the LED display no longer flashes but instead just displays \$0\$.
Here is the test code for the Arduino that I am using:
void setup()
pinMode( 2, OUTPUT );
pinMode( 3, OUTPUT );
pinMode( 4, OUTPUT );
pinMode( 5, OUTPUT );
pinMode( 6, OUTPUT );
pinMode( 7, OUTPUT );
pinMode( 8, OUTPUT );
void loop()
digitalWrite( 6, HIGH );
digitalWrite( 7, HIGH );
for( int i = 0; i < 10; ++i )
digitalWrite( 8, LOW );
digitalWrite( 2, i & 0x0001 != 0 ? HIGH : LOW );
digitalWrite( 3, i & 0x0002 != 0 ? HIGH : LOW );
digitalWrite( 4, i & 0x0004 != 0 ? HIGH : LOW );
digitalWrite( 5, i & 0x0008 != 0 ? HIGH : LOW );
digitalWrite( 8, HIGH );
delay( 1000 );
Further Information: The following code works as expected:
void setup()
void loop()
digitalWrite( 2, HIGH );
digitalWrite( 3, HIGH );
digitalWrite( 4, LOW );
digitalWrite( 5, LOW );
delay( 1000 );
digitalWrite( 3, LOW );
digitalWrite( 4, HIGH );
delay( 1000 );
