I'm trying to find pieces (comparators or op amp) to make a window voltage comparator. My window range is 180VDC to 230VDC. Did you ever heard of high voltage input comparators? I don't need a high voltage supply, all I want to do with my window is to drive a LED to know if the voltage is in the window of not.
Thanks a lot
Boris
