The MAX7219 (datasheet) is a LED matrix driver that's designed to drive an 8X8 single-colour LED array. tronixstuff has an intro on how to use it with an arduino that has some relevant diagrams.
I'm wondering if it's possible to use the chip to drive a 4x4 common-cathode RGB LED matrix? This is effectively 3/4 of the intended matrix, so if it weren't for the common cathode aspect, it would be easy. But the chip only has 8 in and 8 outs, so it would not work to treat it that way, because all three 4x4 matrices share only 4 cathodes, so there will be interference.
So I'm trying to figure out if it's possible to get around this problem in a not-too-painful way, perhaps using some kind of charlieplexing scheme. Or should I just give up and go back to 74HC595Ns?
