I have extracted a strip of 6 LEDs from a LED strip that has these caracteristics :
LED Quantity 300leds Input Voltage 12V Power 72W/5M Cuttable Every 3LEDS Package 5 meters/reel
I have calculated that the 300 led draws 6A (http://www.supercircuits.com/resources/tools/volts-watts-amps-converter) So that 6 LEDs should draw 0,12A (6*6/300)
So I have deduced that powering those 6 leds with 9V, I should use a 9 = 0.12*R R = 75 ohms
I chose to use a 68 ohms resistance, not having a 75 one.
The problem is that when I wire the circuit, I have half the luminosity using the resistance than when I don't use it. Best of all, if I use a 150 ohm resistance, it's almost the same effect.
What did I miss ?
Thank you for your help.
