I took an IR LED transmitter, and soldered it to a mono audio jack (positive pin to the left channel, negative to mass). Now, the LED is quite small, and I'm pretty sure that the phone audio output voltage is enough to power it on.
If I connect a multimeter to the jack and put it on the diode check mode, the LED turns on (I can see it glow violet using a camera). However, if I connect the jack to my phone, turn the volume at 100% and play a WAV file, the LED doesn't light.
I have searched the internet, and found that some other people had my same idea, however most of them used a stereo jack and soldered the LED pins to the Right and Left channels of the jack connector, and left mass unused.
I don't understand why is that, and why my LED doesn't work. Did I miss something?
