I'm needing to create a booster and the easiest schematic I've found is this: http://electronics-diy.com/500mW_FM_VHF_Transmitter_Amplifier_Booster.php however, they do not document what part they use for the amp. Does anyone know what amp they may use? Or a similarly easy way to create booster inexpensively?
The MAX2650 LNA (Low Noise Amplifier) is not the amplifier they are using, but it may be suitable, depending on the gain you want. The MAX2650 has a gain of 18.3dB at 900MHz. If you need higher gain you can cascade a couple of them.
The one in the schematic you linked to is an MMIC (Monolithic Microwave IC), like Leon says. MMICs often consist of just a couple of transistors. This is a typical MMIC package:
Notice that it has two ground pins on opposite sides for improved PCB layout, but that also means that the power supply has to share a pin with the output. The MAX2650 comes in a SOT-143 package and has separate pins for these.
\$\begingroup\$ What exactly is the purpose of the link? \$\endgroup\$– EarlzCommented Jul 21, 2011 at 18:05
\$\begingroup\$ @Earlz - Oops, my bad! :-) Fixed. \$\endgroup\$– stevenvhCommented Jul 21, 2011 at 18:12
\$\begingroup\$ Ok much better. I'm stilling learning about how this will work and build it, but out of curiosity, do you think this would require a heatsink? My gut instinct is no, but I can't quite tell how much 320mW might be \$\endgroup\$– EarlzCommented Jul 21, 2011 at 18:28
\$\begingroup\$ @Earlz - The MAX2650 comes in a SOT143 SMT package, so you can't mount a heatsink on it. You do want lots of copper though, for shielding, and that will also work as a heatsink. \$\endgroup\$– stevenvhCommented Jul 22, 2011 at 5:26
As Leon says - MMIC is the name you want. Go to Digikey and search for MMIC and go from there.
For the same pinout style you could use
In stock at Digikey for $US3.44 in ones.
That's a 10 GHz part !!! You can get functionally similar ones for under $US1 with lower bandwidths.
That's known as a Micro-X 4 package.
Digikey has about 5 different parts available in 1's in stock.
Surprisingly, I find that the one I listed above is the cheapest Micro-X 4 available in 1's and in stock.
If you are willing to go to a different package, same principle otherwise, there are many more available.
Cheapest is BGU7031 from NXP. 1 GHz.
They say
1.2 Features and benefits
Internally biased
Flat gain between 40 MHz and 1 GHz
Noise figure of 4.5 dB
High linearity with an IP3O of 29 dBm
75 Ω input and output impedance
ESD protection > 2 kV Human Body Model (HBM) on all pins
1.3 Applications
Terrestrial and cable Set-Top Boxes (STB)
Silicon and “Can” tuners
Personal and Digital Video Recorders (PVR and DVR)
Home networking and in-house signal distribution
It's an MMIC. At VHF virtually anything should do, such as the $1.25 MCL MAR-1+. I've constructed similar amplifiers by mounting the parts directly on a scrap of PCB material.
\$\begingroup\$ Upvoted because it's you who tossed the term "MMIC", and both other answers refer to it. Still I think your answers are often a bit too brief. You don't even say what MMIC stands for, for instance. \$\endgroup\$– stevenvhCommented Jul 22, 2011 at 5:30
\$\begingroup\$ @stevenvh, Google can easily find the definition of MMIC, so that's trivial. The answer is adequate for a specific pragmatic question for someone who is familiar with RF topics (as someone plans on building a VHF RF amplifier from a schematic should be). \$\endgroup\$– mctylrCommented Jul 30, 2011 at 3:50
