The setup is as follows:
DC Motor: Brushed DC Motor
PNP NPN standard H Bridge with 4 numbers of 1N4448 for flyback protection.
Stall current of the Motor: 200 mA (Stalling is expected)
Typical load current is 80 mA.
Motor cannot run freely unless driven.
DC resistance of Motor in OFF condition is 13 Ohms.
Voltage applied across Motor varies from 2.2 to 3 V depending on battery voltage.
How to calculate the time taken to discharge the current through the flyback diodes and DC motor when Motor is turned OFF suddenly?
The inductance of Motor Measured using Agilent LCR meter is about 8.12 mH.
Edit: Purpose of this is to have an idea on the delay to be introduced before driving the motor in other direction, if it makes sense
