I'm trying to establish communication between Atmel Atmega32U4 (used in Arduino Leonardo) on MCU PCB and TI DAC8552 on PSU PCB via isolated SPI link. For isolation I'm using Silicon Labs Si86xx digital isolator which can go up to 150MHz. While everything works as expected WITHOUT isolator I got a quite strange results when isolator is put in between MCU and DAC device. For testing is used very simple Arduino sketch which sending in infinite loop two values to the DAC each last 20ms:
#include "SPI.h"
int DAC2_SELECT=5; // uncomment this line if Arduino board is used instead of PSU MCU board
int IO_EXPANDER2=6; // uncomment this line if Arduino board is used instead of PSU MCU board
int ADC2_SELECT=13; // uncomment this line if Arduino board is used instead of PSU MCU board
int var=0;
void setup()
  // Deselect devices that share same SPI bus on the PSU post-regulator board
  pinMode(ADC2_SELECT, OUTPUT);
  digitalWrite(ADC2_SELECT, HIGH); // Deselect ADS1120
  pinMode(IO_EXPANDER2, OUTPUT);
  digitalWrite(IO_EXPANDER2, HIGH); // Deselect MCP23S08
  // Initialize DAC8552
  pinMode(DAC2_SELECT, OUTPUT);
  SPI.begin(); // wake up the SPI bus.
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(0);  //CPOL=0, CPHA=0
  // SPI.setClockDivider(SPI_CLOCK_DIV16); // Slow down SPI clock speed to 1MHz for testing purpose
  digitalWrite(DAC2_SELECT, LOW);
  SPI.transfer(B00100100); // Write to Data Buffer B
  SPI.transfer(0x99); // send first byte
  SPI.transfer(0x99);  // send second byte
  digitalWrite(DAC2_SELECT, HIGH); // Deselect DAC
void loop()
  SPI.transfer(B00010000); // Write to Data Buffer A
  SPI.transfer(0x20); // send first byte
  SPI.transfer(0x00);  // send second byte
  delay(20);
  SPI.transfer(B00010000); // Write to Data Buffer A and activate channel A
  SPI.transfer(0x80); // send first byte
  delay(20);
Schematic derived from much complex one is shown below:
Results WITHOUT isolator:
DAC output without isolator
Connection between MCU and PSU PCB:
MCU-PSU PCBs connection without isolator
Here is what I got when isolator is added between MCU and DAC:
DAC output with isolator
I tested it using isolator on MCU PCB ...
MCU-PSU PCBs connection with on-board isolator
but also to be sure using isolator connected on breadboard to be sure that something is connected wrongly to the MCU PCB:
MCU-PSU PCBs connection with isolator on breadboard
Please note that MCU PCB has two 10-pin IDC connector: black one is a non-isolated SPI, and grey is isolated SPI where "remote" part of the isolator device is supplied from external source (PSU PCB). Intentionally I used the same ribbon cable, and cable length doesn't seems that is an issue since everything works correctly without isolator. To be completely on safe side I tried to slow down SPI clock as much as possible even down to 125kHz (divide by 128 from default 4MHz or divide by 4). Nothing helps in case of isolator - I'm continuously receiving random values on the output instead of fixed two. I also tested the following "hybrid" connection where MOSI and chip select (ADC2_SELECT) goes thru isolator and SCLK is connected directly while MCU ground IS NOT connected to "remote" PSU ground. To my surprise that combination works but I cannot explain why! Also checking signal from the both side of isolator don't shows anything suspicious: signal duration on the "remote" side is slightly shorter since isolator has built-in Schmitt trigger logic.
I ran out of ideas what to test next so if someone has any suggestion please let me know.
EDIT 2015-06-08: I'm adding below two screenshots side by side where on the left is DAC out when SPI is connected directly. It seems that setup of new value is in sync but for some reason value is "shifted" up or down in case of lower value (0x20).
DAC out 0x20 to 0x80
When change is from 0x70 to 0x80 I got the following:
DAC out 0x70 to 0x80
EDIT 2015-06-09: Please find below more measurements as suggested by Tom L. Everything is performed on the breadboard, same wires and flat cable is used as in initially presented results. Grounds on both side of the isolator are tied together, "remote" (or Side B) is supplied from PSU PCB, host (or Side A) from Arduino Leonardo. First I tired using mentioned wiring direct SPI connection and it works as expected. In first step SCLK and MOSI stays directly connected CS (ADC2_SELECT) goes over isolator. All unused isolator pins are grounded. DAC works as you can see on the following two screenshots (S1 is host side, S2 is remote side on the isolator device, DAC signal is analog output on DAC8552 pin 4 (VOUTA):
CS isolated
CS isolated (10ms)
Same thing when MOSI goes thru isolator and SCLK and CS stayed directly connected:
MOSI isolated
MOSI isolated (10ms)
And now we comes to problem that persist and I cannot figure out what is going on: when SCLK goes thru isolator communication stops regardless of the fact that signal looks fine on both side of the isolator. Please note that on DAC trace there is no more changes. That is one of two possible scenario. Another one is already described (random values are presented on DAC output).
SCLK isolated
SCLK isolated (10ms)
I'm adding one additional scenario when SCLK is connected to host side via capacitor. In that case DAC starts to behave regularly even when grounds are not tied together. Pleas find below schematic and result:
SCLK via 22pf schematic
SCLK via 22pf
  • \$\begingroup\$ Your schematic cannot be correct. You have +5V/1 directly connected to GND1 and a cap in series between +5V/1 and IC24 Vdd1! Please post the correct schematic. \$\endgroup\$
    – DoxyLover
    Commented Jun 7, 2015 at 16:42
  • \$\begingroup\$ Also, have you tried running everything through the isolator but connecting the grounds together? It almost looks like the channels are mixing together. \$\endgroup\$
    – DoxyLover
    Commented Jun 7, 2015 at 16:48
  • \$\begingroup\$ Thanks, I made correction in schematic. Also tying grounds together didn't make any improvement. \$\endgroup\$
    – prasimix
    Commented Jun 8, 2015 at 10:00
That output signal looks like you connected two outputs to each other (SDO?) or a clock to some other output. Switch your device off and measure if your connections are correct.
Also, which part exactely are you using, since there are a few variants with different input/output configurations.
Edit 2015-06-08:
Alright, we'll have to do this step by step.
  1. Connect the grounds (Primary and secondary side of isolator). This will make sure they are actually a the same potential.
  2. Verify that you configure the pins on your microcontroller correctly (disable internal pull-ups, so you should see that you are actually using them as outputs and not as High-Z/Low configuration)
  3. Verify that your connection works without the isolator.
  4. Connect CS through the isolator, measure level before and after isolator and verify if your connection works. Leave all other connections connected directly.
  5. Now do the same for MOSI (use the same pin on your isolator as you did before with CS)
  6. Do the same with SCLK (again, use only the pin on the isolator your tried before)
Which items work, and which don't?
  • \$\begingroup\$ Device variant is Si8662 as stated in schematic. Yes, this probably looks like signals are mixed but I didn't find in any of tested cases (PCB, breadboard and even Arduino instead of my own MCU PCB) that wiring is incorrect. \$\endgroup\$
    – prasimix
    Commented Jun 8, 2015 at 11:47
  • \$\begingroup\$ Maybe a short in one of the cables? Can you measure resistance between the various signal lines when cables are connected. \$\endgroup\$
    – Tom L.
    Commented Jun 8, 2015 at 11:54
  • \$\begingroup\$ Thanks Tom. Yes, I now even tested with ohmmeter if something is wrong with wiring. Unfortunately that is not a case and as you can see I used the same stuff for various testing cases. Something that I really don't understand and what is already mentioned in main section is how is possible that it not just works correctly but works at all when SCLK is connected on the host side and CS and MOSI via isolator and that host and remote are galvanically separated!? \$\endgroup\$
    – prasimix
    Commented Jun 8, 2015 at 12:46
  • \$\begingroup\$ I added something to my answer, can you please play through these items? \$\endgroup\$
    – Tom L.
    Commented Jun 8, 2015 at 17:17
The whole misery is generated by wrongly declared SPI clock mode. I even put in sketch as an reminder the following comment: CPOL=0, CPHA=0 what is SPI_MODE 1 and for that in Arduino IDE exists constant SPI_MODE1 what is not equal to 0.
So, for the correct working the following command has to be used:
SPI.setDataMode(SPI_MODE1);
EDIT: My understanding of CPHA was wrong. CPHA 0 is not falling edge what DAC8552 require but rising edge. The right CPHA has to be 1 and not 0.
