I'm doing a project at work that has a couple of esoteric requirements, particularly for a 0.1 Hz (0.07 Hz really, due to part availability limitations) Highpass filter (in the data acquisition system).
Right now, I'm using a 22uF film cap, and 100K resistor, and the whole affair works quite well. However, the film cap is enormous (1.240" L x 0.532" W), and the resultant PCB is really a very large (there are many channels).
I really don't want to go too much higher for the R in the filter, since it's going into an op-amp. With the existing system (OP27, need the really low 1/f knee), +-10nA bias current, you get \$10*10^{-9}A*100,000\Omega = 0.001V,\$ or 1mV of offset due to bias current.
WIMA used to manufacture some compact 22uF 16V film caps, but they have EOLed them without a replacement.
Unfortunately, the application is a bit extreme. The caps need to be able to handle extremely low temperatures, and hard vacuum, which I think means electrolytics are out.
Does anyone manufacture large, low voltage film caps (voltages in question are +-5V, nothing major)? Alternatively, does anyone know how electrolytics fare in vacuum?
