I'm trying to create a simple homemade 3D laser rangefinder using a generic line laser and an IR camera, similar to the setup described here. The line laser and camera would detect depth in two dimensions. I'd then mount these on a servo to sweep it across an angle to track the third dimension. My goal is to use it on a cheap indoor mobile robot for experiments with room mapping without spending $5000 on a "real" 3d laser rangefinder.
Being mindful of eye safety, I'm trying to find an appropriate line laser rated as class 2, but this has become quite difficult. The few line lasers I can find, like this one, give a description (25mW, 810nm, 5V) but don't provide a safety classification.
Based on this description of the safety classifications, the 25mW power rating would seem to imply it's a class IIIb, and therefore potentially quite dangerous:
CLASS IIIb LASERS are systems with power levels of 5 mW to 500 mW (CW) and some pulsed lasers. These lasers will produce an eye hazard if viewed directly. This includes specular reflections. Administrative, Engineering, and PPE control measures are required. (Especially laser safety glasses!)
Does this classification and danger seem correct?
Since my application involves shining it around a home, I want to make sure it doesn't blind anyone. How can I ensure this is safe for home use?
Ideally, I'd like to find a 2.5-5mW infrared line laser, but no one seems to sell anything like this. Most seem to be 25mW or stronger. Could I control a stronger 5V laser's duty cycle by connecting it's +5V lead to an Arduino pin and generate a PWM output of 10% to give a 25mW laser an effective 2.5mW output?
Also, what minimum power would I need to make an effect laser rangefinder? Even if I did find a 5mW line laser, would that be bright enough to detect a couple meters away?
