My PCB needs to export four sets of voltages to our customers' PCBs. Eight pins in total are needed. Eight pins at my side are to be connected with eight pins at customer's pcb side. Our pcb is to be integrated into customers' system. The system will be put into a box and made a lab device. So I guess stable connections are important. Or during device dilivery, the connector may get disconnected.
However, i do not really know what the customers' connectors are.
Shall I use 1.27mm spacing or 2.54 spacing? At my side, 1.27mm spacing is preferred, which brings to smaller size of pcb. However, 2.54mm spacing seems more common and is compatible easily with ribbon cables.
Shall I use connectors that have directions? Connectors with direction connect more stable. However, the customer has to use the same connector.
I have little experiences designing product. Any advice will be really appreciated!
