hello i'am using FreeRtos API with stm32f4 microcontroller , the program gets stuck when it enters vTaskDelay , when I debug it I see that it is stuck in this line (2588 of tasks.c at function vTaskDelay)
            if( listCURRENT_LIST_LENGTH( &( pxReadyTasksLists[ tskIDLE_PRIORITY ] ) ) > ( UBaseType_t ) 1 )
            taskYIELD();
thank a lot for your help
  • \$\begingroup\$ There are a lot of things that could cause this, but you're probably misusing the mutitasking API somewhere else. \$\endgroup\$
    – Daniel
    Commented Dec 9, 2015 at 0:22
  • \$\begingroup\$ Not enough information provided to answer this \$\endgroup\$
    – Daniel
    Commented Dec 9, 2015 at 0:23
  • \$\begingroup\$ hi @Daniel i discovered that the code never reaches " xTaskIncrementTick " wich means the tick interrupt doesn't execute , how to make it work ? \$\endgroup\$ Commented Dec 10, 2015 at 11:06
well I found the reason why this error happened it's just that time doesn't seem to advance because the systick interruption was like doing nothing , and this because i used a FreeRTOSConfig.h generated with stmcube and the following was commented
/* IMPORTANT: This define MUST be commented when used with STM32Cube firmware,
to prevent overwriting SysTick_Handler defined within STM32Cube HAL */
/* #define xPortSysTickHandler SysTick_Handler*/
, I decommented it , i also had to comment the definition of the systick interruption in stm32f4xx__it.c to avoid duplicate definition
With STM32Cube_FW_F4_V1.13.1 and FreeRTOS V8.2.3 you need to define the symbol USE_RTOS_SYSTICK.
Here is a working example:
#include "stm32f4xx.h"
#include "stm32f4xx_nucleo_144.h"
// don't forget to define USE_RTOS_SYSTICK globally!
#include <cmsis_os.h>
#define LED_PIN     GPIO_PIN_0
#define LED_PORT        GPIOB
void blinky_task( void* pvParameters)
    for(;;)
        vTaskDelay( 1000 / portTICK_PERIOD_MS);
        HAL_GPIO_WritePin( LED_PORT, LED_PIN, GPIO_PIN_SET);
        vTaskDelay( 200  / portTICK_PERIOD_MS);
        HAL_GPIO_WritePin( LED_PORT, LED_PIN, GPIO_PIN_RESET);
int main(void)
    HAL_Init();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    GPIO_InitTypeDef GPIO_InitStructure;
    GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStructure.Pin  = LED_PIN;
    HAL_GPIO_Init( LED_PORT, &GPIO_InitStructure);
    xTaskCreate( blinky_task, (char*) "blinky", configMINIMAL_STACK_SIZE, 0, 1, 0);
    vTaskStartScheduler();
