I am working on a simple FM radio receiver. Built the circuit and it works very well. Learned few new things, and got some questions, especially the output stage. The Op-amp 2822 is a dual op-amp, but the output is only mono. One of the op-amp output is connected to one side of the speaker and other output to other side. The speaker doesn't connect to the ground in this setup, Very strange. there is Also a 10u electrolytic capacitor connected to the inverting inputs of these 2 op-amp. will a normal 104 ceramic cap works? and also what are the purpose of C11, C12, C14 and R6?
Another thing is CF2 and CF1; Are they ceramic resonators? but one has 3 leads while other only 2. and do they have polarity?
last very interesting thing is from the input stage. There are 2 resistors connected to the collector of the 9018, and there is a biased resistor 150k connected in between. what is the benefit of this setup? (instead of using one collector resistor and connect the biased resistor to the collector directly. )
