I am living in an about 30 years old apartment in China.
Sometimes when I am touching my Mac Book (aluminium case) I would get little electric shocks. I measured the voltage between my Mac Book case and ground to be roughly 10V, there is a current of around 1mA constantly flowing through me. :/
Another weird effect is, when I am using an LED light in my room, there constantly is a voltage of 30V even when the switch is turned off!! That seems to be some serious ground loops!
When I plug my electric guitar, I am also getting some slight shocks while playing.
So I started to make some measurements with my multimeter.
I found out that when I measure the voltage between the ground pole of an electric plug with a metallic water tap in my room, there is a potential difference of nearly 100V (!). I also measured one phase to ground to be around 120V and another phase to ground to be around 100V, so none of them are being "neutral".
Now the question is: How do I resolve this issue?
I am already using a wire to connect the case of my laptop manually with the metallic water tap (that makes most sense to me to call "ground"). Like that at least I can partially get rid of the little shocks through my body. Now, what would happen if I connected the ground pole of the electric plug (that I have measured to be at 100V) with my water tap? Would that elevate the ground for the whole apartment to "zero"? Or would that be very dangerous?
Don't worry, I will not try it out until I am sure about what I am doing.
