I would like to do a bit of prototyping and have been wanting to leverage edge connectors as it would make my layout a whole lot easier. When using these, are you forced to get some kind of prototyping board that has built in fingers like this:
Do they sell stand-alone, through-hole fingers that can be added to a pre-existing prototyping board? Maybe the connector and plug as a bundle? I'm looking for something very specific... ~60pin, through-hole, ideally wire-wrap.
On a side note, if anyone knows where to even get the boards with built-in edge connectors that would be great too. I can't really find any but that's probably because I don't know the proper search terms.
Probably no. You may want to roll your own board for this.
  • \$\begingroup\$ Gold plating and chamfering will cost extra. \$\endgroup\$
    – CL.
    Mar 24, 2016 at 7:54
  • \$\begingroup\$ How do you do this? You mean create it yourself based on specifications out there? \$\endgroup\$
    – Dave C
    Mar 24, 2016 at 20:50
  • \$\begingroup\$ @DaveC Yes. There are drawings on how the fingers should look like. \$\endgroup\$ Mar 25, 2016 at 6:33
