I have a DC switch rated at 2A at 36VDC, if I were running the switch at 4VDC what would be the maximum current I could safely run through it?
I'm assuming I can't simply use the wattage to calculate and I can't find a straight answer. Thanks for the help!
EDIT TO CLARIFY: It is a momentary spst on/off switch rated at 2a 36vdc being used on a high amp low voltage DC circuit.
