If I had a 10 kW hydro electric generator (including turbine drive), what formula would I use to calculate how much water per second would need to be pumped into the turbine at 700 kpa to generate the 10 kW of electric power that the generator is rated to produce (assuming the turbine was 92% efficient & the motor was 90% efficient)?
This is not a homework problem. I'm just curious how this is calculated.
I noticed a power formula at the following url, however, given that "head" in the equation doesn't seem to make sense in a pump driven system, I'm wondering if anyone can help me further. It seems that pump pressure & flow rate should be in the calculation, however, when I leave out the "head" height, the answer seems high. Would a 1 m\$^3\$/s flow rate through a 92% efficient H\$_2\$O turbine produce 9,021.52 watts?
See Water turbine - power on Wikipedia.
