Why people use \$Z_g\$ in the following circuit:
As \$Z_g\$ doesn't appear in \$V_{out}\$ equation: \$-Z_f/Z_i \times V_{in}\$
    \$\begingroup\$ It's there to balance out the input bias currents. Read any intro to opamps or search "opamp input bias currents" for more information. What it's doing in this circuit, only its designer knows : the TL081 has substantially zero bias current... \$\endgroup\$
    – user16324
    Commented May 25, 2016 at 14:13
    \$\begingroup\$ Pretty sure that the TL081 issue is the fact that it is the default opamp selected when drawing schematics in CircuitLab - just popped into my head the other day. I think the OP is using it to represent an opamp in the original schematic - not necessarily a TL081. \$\endgroup\$
    – stefandz
    Commented May 31, 2016 at 9:34
  • \$\begingroup\$ @stefandz, quite indeed! \$\endgroup\$
    – Tar
    Commented May 31, 2016 at 12:03
The resistor Z_g is sometimes needed to keep the DC offset of the amplifier as low as possible.
Imagine that Z_g was not present, then the + input of the opamp is always 0 V. Most opamps have a small DC input current flowing into or out of the inputs, see the datasheet how much this is. This small current will flow through Z_i and / or Z_f and it will cause a voltage drop across these resistors. This causes an offset error at the - input. To introduce a similar error at the + input, Z_g is used, it usually has a value which is the value of Z_i and Z_f in parallel. Now both inputs have the same offset error due to the input biasing current, the opamp only amplifies the voltage difference, we just eliminated that difference, now the offset (due to the input biasing currents) is gone !
For an explanation by Dave Jones, see the EEVBlog about opamps
As the others mentioned, for the TL081 this is not such an issue as it has JFET inputs. Also opamps with MOS inputs do not suffer from this. Mostly for opamps with BJT inputs this Z_g is needed, opamps like the 741 or NE5532 for example.
The resistor Z_g is there to ensure that the offset voltage at the positive and negative terminals of the opamp is as close to identical as possible (hence not affecting the circuit, as it appears as common-mode offset).
By making the input bias current at each terminal (which should be approximately the same) flow through identical impedances, you should end up with the same voltage offset at each node. Hence Z_g is calculated to equal the same impedance as would be seen "looking out of" the inverting input:
\$Z\_g = Z\_i || Z\_f = {{Z\_i\times Z\_f} \over {Z\_i + Z_f}} \$
As Brian Drummond points out, with the TL081 having a JFET input stage and an input bias current that you would need very expensive equipment to measure, practically speaking it is likely to be redundant in this particular schematic.
However, it is also likely that since the TL081 is the default opamp selected by CircuitLab when drawing a schematic I imagine that your original schematic may be for a different device, where this technique has a greater effect.
  • \$\begingroup\$ Just to be certain about it, why are Z_i and Z_f in parallel in Z_g calculation? \$\endgroup\$
    – Tar
    Commented May 30, 2016 at 21:24
  • \$\begingroup\$ There's a good explanation of that here: ecircuitcenter.com/Circuits/op_ibias/op_ibias.htm \$\endgroup\$
    – stefandz
    Commented May 31, 2016 at 9:32
