I have a resistive heater with a resistance of 18 Ohms. The heater is mounted on a job which has a thermocouple mounted on it. I need to use a SSR based controller to control the temperature measured by the T/C. As per my calculation I need to produce 1500 W. I have at my disposal a 230 V, 50 Hz power source, rated at 16A.
I plan to use an isolation transformer to drop the 230V to 165V with the SSR and the heater mounted on the secondary side.
My question: An SSR will generate a number of harmonics due to "chopping" of the sine wave. Question is will these harmonics lead to heat generation in the secondary winding of the transformer?
