I found this component between my supply of resistors, motors, Arduino etc: (ruler for scale) Image of the component
It is a small black cuboid (.4cm x .4cm x .2cm) with 2 pins (1.7cm) connected to it. On the front face is written in white:
2C1
100V
83 26
On the top:
470pK
Does somebody know what component this is and what the numbers written on it mean?
    \$\begingroup\$ 100 V 470pF capacitor. \$\endgroup\$
    – winny
    Commented Jul 13, 2016 at 7:47
  • \$\begingroup\$ @winny So can it handle a voltage of 100V? Seems a lot to me for such a small component? \$\endgroup\$ Commented Jul 13, 2016 at 7:56
  • \$\begingroup\$ Yes it can. Try it! \$\endgroup\$
    – winny
    Commented Jul 13, 2016 at 8:01
    \$\begingroup\$ tolerance 10%, for completeness. \$\endgroup\$
    – Antonio
    Commented Jul 13, 2016 at 8:03
This is probably a 47 pF 100 V capacitor.
Capacitance values on small parts like this are almost always expressed in a floating point format. In this case, most likely, the first two digits are the mantissa and the last the exponent of 10. "470" therefore means "47 x 100". We guess that the units is pF, but that is almost universally the case.
  • \$\begingroup\$ What does the pK mean? \$\endgroup\$ Commented Jul 13, 2016 at 17:26
  • \$\begingroup\$ @Todd: Not sure without a datasheet. "p" might indicate picofarads, and "K" could be a temperature range. Just guessing though. \$\endgroup\$ Commented Jul 13, 2016 at 18:44
