I am using usbasp with atmega16a. I try to use external crystal 16MHZ with 22p capacitor. With mistake i use this command to change the fuse setting.
avrdude -c usbasp -p atmega16 -U lfuse:w:0b00000000:m hfuse:w:0b10011001:m
The atmega16a is dead. How to fix it?
pls. Any solution:
  • \$\begingroup\$ I first assumed you had by mistake set the fuse settings incorrectly. But I guess it is unlikely you would make the same mistake twice. Nevertheless I would first check the XTAL2 pin with a 'scope to see if the clock was running. \$\endgroup\$ Commented Sep 7, 2016 at 14:05
  • \$\begingroup\$ @RedGrittyBrick What does it mean check XTAL2 pin with a 'scope to see if the clock was running'? But then i try to run with atmega8l still not working internal crystal. How i reset usbasp to factory setting? \$\endgroup\$
    – Alex Cerry
    Commented Sep 7, 2016 at 14:21
  • \$\begingroup\$ @AlexCerry There is no "internal crystal" in Atmega, only simple RC oscillator. \$\endgroup\$ Commented Sep 7, 2016 at 14:37
  • \$\begingroup\$ @lustful-rat how i solve this problem? \$\endgroup\$
    – Alex Cerry
    Commented Sep 8, 2016 at 1:04
  • \$\begingroup\$ I change the question now usbasp working with atmega8l. But not working with atmega16a. \$\endgroup\$
    – Alex Cerry
    Commented Sep 8, 2016 at 1:26
if you are using windows os there are avr studio 4 is available. in this ide you can modify your fuse bits and it is one type gui based software which indicates your all fuse bytes and all.
