1 led strip = 3a, 36w, 12v, 16.5ft ..............6 strips= 18a, 216w, 12v, 99ft
Will this transformer/ power supply (20A, 240w) be capable of handling the 6 strips with the specs mentioned above? Each strip has on its end an external female power adapter that can be plugged with any 3a male power adapter.
1- Which gauge of wire would be sufficient to use for power supply to the female adapter, I have 100ft of 12AWG and will option 1 of having the transformer in middle and run 50ft to left and right be best or with a 30A, if that.
2- Will running two 20a transformers linked to that ONE power feed cause issues?
// Each strip are connected to one another and power on but dim thus the need for external power. I think of it more like a water hose being pushed by two outlets from each end to maintain pressure :-D
