In the given circuit, while finding Norton or Short circuit current, we short terminal A and B. So I have assumed that is(t) = short circuit current. Is it correct to assume so? I did it because as terminal A and B are short circuit, all the current is(t) has zero resistance path to ground. Is my analysis correct?enter image description here
  • \$\begingroup\$ What about the voltage source? \$\endgroup\$
    – user110971
    Commented Nov 11, 2016 at 23:06
  • \$\begingroup\$ Yes, What about it? \$\endgroup\$ Commented Nov 11, 2016 at 23:07
  • \$\begingroup\$ it also provides current. \$\endgroup\$
    – user110971
    Commented Nov 11, 2016 at 23:08
  • \$\begingroup\$ Yes, of course it does, but that results in current flowing through C1 and other elements. But the short circuit current through terminal AB will remain is(t). Is that not correct? \$\endgroup\$ Commented Nov 11, 2016 at 23:10
  • \$\begingroup\$ draw the short circuit. What happens to L2? What about the current through L2? \$\endgroup\$
    – user110971
    Commented Nov 11, 2016 at 23:12
We're using superposition to establish the short circuit curent. When ignoring \$i_1\$ we can calculate the impedance between terminals A and B:
$$ Z_{AB} = j \omega L_2 + \frac{1}{j \omega C + 1/R} $$
leading to a current of $$ i_{u1} = \frac{u_1}{Z_{AB}} = \frac{u_1}{j \omega L_2 + \frac{1}{j \omega C + 1/R}}$$
This is the first partial current. Now, if we consider \$i_1\$ and replace \$u_1\$ with a short circuit, \$i_1\$ is connected directly between terminals A and B. Thus:
$$ i_{short} = i_1 + i_{u1} $$
So you are half correct. The short circuit current consists of a part \$i_1\$ and a part \$i_{u1}\$ contributed by the voltage source.
