I'd like to string together 10 of these Cree LEDs in a series circuit (Vf: 3.0v, Imax: 0.3A): http://www.cree.com/LED-Components-and-Modules/Products/XLamp/Discrete-Directional/XLamp-XQA
I think this constant current driver should be suitable given it can output up to 35v @ 0.3A: http://uk.rs-online.com/web/p/led-drivers/7063213/
I've done a fair bit of research but my only electrical knowledge dates back to my school days so I'm hoping someone can advise as to whether this really is a suitable driver?
Also if I were to increase the number of LEDs to 12 (requiring a total of 36v) would the LEDs function as normal but the last one appear dimmer?
Lastly, I'm unsure if I should add a dropping resistor at the start of the circuit, and if so is the following calculation (for 10 LEDs) correct?
R = (Vs - Vf) / I
R = (30 - 3) / 0.3
R = 90 ohms *seems very low!*
Please assume minimal knowledge (but a desire to learn)!
Thanks
To answer your questions in order:
Yes. It looks like it will work.
No. LEDs don't work like that. If you go over the maximum voltage requirement then all of the LEDs will be off.
No resistor in series with the LEDs is needed. You use a resistor to drive an LED if you have a constant voltage driver. This is a constant current driver and so no resistor is needed, all it would do is waste power.
You do however need a capacitor on the power input. The data sheet gives examples of both minimum and recommended connections for a range of operating modes.
I would also recommend adding a couple of resistors to the analog dimming input to bring the drive current down to about 200mA. You'll get a lot more life out of the parts if they aren't being driven right to the limit of their operating range and the change in brightness will be barely noticeable.
  • \$\begingroup\$ great, thanks! I'll be modulating the brightness with the analogue input using a raspberry pi and DAC link so can restrict the max current via software. As for the capacitor - is this for the snubber circuit to smooth supply spikes when switching on? From the data sheet this appears to be 10 micro farad with an unlabelled resister, does that seem correct? Supply voltage will be 12v. \$\endgroup\$
    – milks
    Nov 15, 2016 at 13:23
  • \$\begingroup\$ The text indicates a 1 ohm resistor in series with the cap. They also indicate a lot of additional caps etc... for EMI reasons. For a home product rather than something you'll be selling you can probably miss these out but keep an eye out for radio interference. \$\endgroup\$
    – Andrew
    Nov 15, 2016 at 14:03
The typical forward voltage of the white LED is 3.0 volts but it may be as high as 3.3 volts (read the data sheet). This means that 12 LEDs could require a voltage of 39.6 volts.
Given that you only can supply 35 volts your driver would go into constant voltage mode (limited at 35 volts) and this would produce a relative brightness of 75% compared to running at full current: -
So, the top graph is the individual forward voltage for 12 identical devices in series powered from a 35 volt power supply (35/12 = 2.91). With 2.91 volts, the likely current is going to be around 120 mA then, going to the bottom graph, that reduced current results in 75% of the luminous flux.
  • \$\begingroup\$ thanks, that's really useful. I'd been referencing the datasheets though they can be a little bewildering \$\endgroup\$
    – milks
    Nov 15, 2016 at 13:58
