Here is the assignment:
The assignment is to calculate various values across the circuit.
Here are the important values:
\$R=3.3k\Omega\$
\$ U_1 = U_2 = 4 V\$
The diodes are ideal with the following current voltage relation:
Here is my thought process what I tried and where I failed: I am assuming all diodes are on because there is nothing directly blocking them, like an air valve.
Lets say I want to calculate \$I_5\$. I know \$I_5\$ is half of \$I_2\$ and is equal to \$I_6\$ and \$I_7\$.
The resistance should be \$2R\$ and the Voltage should be because the diodes are in parallel \$4V- 1.4V = 2.6 V \$
But then it all stops making sense after I try to calculate it, something must be wrong with my approach.
Here are my questions:
How do I go about this circuit,how do I split up this circuit in to the correct Kirchhoff meshes ?
Can you give me a hint or a direction how I would go about solving this ?
