I'm trying to make my STM32 communicate VIA Can. Therefore I'm making use of the CAN transceiver MCP 2551. In many circuits I've seen a 100 nF between Ground and Vdd. What is the reason for that? Here an example:Example schematic showing a MCP2551 with 100nF capacitor between VDD and VSS
It's called a decoupling or power supply bypass capacitor. It's used to reject noise from the supply pins of an IC.
  • \$\begingroup\$ Ok thanks! How do I determine which capacity is needed for a decoupling capacitor? \$\endgroup\$
    – cylex
    Commented Dec 19, 2016 at 21:23
  • \$\begingroup\$ Dig around dim's links for some good suggestions and explanations if you're curious, but the most common (that I've seen) is 0.1uF. \$\endgroup\$ Commented Dec 19, 2016 at 21:29
