I'm working on a temperature sensor. I've got:
- LM35 (Sensor)
- LM741 (Op-amp to amplify LM35 Vout to 5V)
- PIC 14F458
The temperature is shown on two 7-segment displays with only one BCD converter (4511). Therefore I multiplexed these two displays.
The problem is that my 7-segment displays are flickering a lot and I don't know why.
If you want to see the simulation on Proteus: LM35 - SSD
Here's the schematic diagram on Proteus :
And here's the C code on CCS.
#include <sonde2.h>
#include <math.h>
#define CONV_CST 0.48875855327
#define TRESHOLD 25
#define TENS_DISPLAY PIN_E0
#define UNITY_DISPLAY PIN_E1
#define GREEN_LED PIN_C0
#define RED_LED PIN_C1
int simpleBCDConverter(value) {
// Shift tens from 4 bits to the left
// So we have ([Tens] [Unity]) XXXX XXXX
return ((value / 10 % 10 << 4) + value % 10);
* Convert a number of 10 bits to its BCD equivalent
void bitsToBCD(int value) {
int tens = value / 10 % 10;
int unity = value % 10;
output_high(TENS_DISPLAY);
output_d(tens);
output_low(UNITY_DISPLAY);
delay_ms(10);
output_high(UNITY_DISPLAY);
output_d(unity);
output_low(TENS_DISPLAY);
delay_ms(10);
* Check temp level, and switch on the right led
void checkLed(int temp) {
// If temps is greater than treshold
// Blinking Red LED with 555 (astable)
if (temp > TRESHOLD) {
output_low(GREEN_LED);
output_high(RED_LED);
} else { // Otherwise, green LED
output_high(GREEN_LED);
void main()
setup_adc_ports(AN0);
set_adc_channel(0); // A0 connecté à l'entrée analogique
setup_adc(ADC_CLOCK_INTERNAL);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1|RTCC_8_BIT); // 51,2 us overflow
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //13,1 ms overflow
setup_low_volt_detect(FALSE);
int temperature;
while(TRUE) {
//delay_ms(10);
// Read the value from A/N converter (10bits [0 => 1023])
// And convert it to a range from 0 to 100 (°C)
// 0.48 => (5 / 1023) * 100
temperature = read_adc() * CONV_CST;
// Check temp level
checkLed(temperature);
// Convert bits to BCD
// And show temp on 7 segment displays
bitsToBCD(temperature);
Thanks.
