I'm using the ADC channels (12-bit resolution) of a STM32F0 microcontroller to read voltage values in three different points of a board. What I want to do is to read the values every 2 seconds (I have 2 seconds to read the values in the three points) and send them by the UART interface. In order to select which ADC channel I'm reading I'm implementing the voltage reading functions as follows:
uint16_t readv1(void){
    //Here I try to read ADC_CHANNEL_1
    //chConfig and txtbuff are global variables:
    //ADC_ChannelConfTypeDef chConfig;
    //char txtbuff[64];
    chConfig.Channel = ADC_CHANNEL_1;
    HAL_ADC_ConfigChannel(&hadc, &chConfig);
    uint32_t vref = HAL_ADC_GetValue(&hadc);
    uint16_t vref2 = (uint16_t) vref;
    sprintf(TextBuffer, "%u\n", vref2);
    HAL_UART_Transmit(&huart4, (uint8_t*)txtbuff, strlen(txtbuff), 0xFFFFFFFF);
    return vref2;
This is the function for scanning one ADC channel. For reading the other two ADC channels I'm using the same procedure just changing the value of n in the line chConfig.Channel = ADC_CHANNEL_n; where n is the channel number. Note that chConfig is of the same type of sConfig declared in MX_ADC_Init() function, but chConfig is a global variable.
The problem I have is that readv1 function reads a constant voltage (I have checked it with a voltimeter) but the numbers showed in the terminal via UART change a lot, between 120 and 2400. I'm not sure if using the line chConfig.Channel = ADC_CHANNEL_1; for selecting a channel is good or if there is any other procedure to follow. Or should I use polling mode as follows every time I need to read a single channel?
    chConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
    chConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
    HAL_ADC_Start(&hadc);
    HAL_ADC_PollForConversion(&hadc, 0xFFFFFFFF);
    HAL_ADC_Stop(&hadc);
    chConfig.Rank = ADC_RANK_NONE;
In order to scan the ADC every two seconds I'm using a 8 MHz timer as follows:
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim){
    if (htim->Instance==TIM3){
        //Here I call the functions which read the voltage values of different ADC channels
        volt1 = readv1();
        readv2(volt1);
        readv3(volt1);
This is the main function where I initialize the periphericals (ADC is in interruption mode):
int main(void)
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART4_UART_Init();
  MX_ADC_Init();
  MX_TIM3_Init();
  /* USER CODE BEGIN 2 */
  HAL_ADC_Start_IT(&hadc);
  HAL_TIM_Base_Start_IT(&htim3);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
And below are the initialization functions for the timer and the ADC:
/* TIM3 init function */
static void MX_TIM3_Init(void)
  TIM_ClockConfigTypeDef sClockSourceConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  htim3.Instance = TIM3;
  htim3.Init.Prescaler = 8000;
  htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim3.Init.Period = 1999;
  htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
    Error_Handler();
/* ADC init function */
static void MX_ADC_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = DISABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
    /**Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_1;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_2;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_4;
    Error_Handler();
Update: I have updated the code with the modifications I proposed before. Now I get a stable value but is very low. I have confirmed that I'm always reading the same ADC channel, the instructions I'm coding are not changing the ADC channel before doing the read. Below is the whole code with the modifications:
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f0xx_hal.h"
/* USER CODE BEGIN Includes */
#include "string.h"
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef hadc;
TIM_HandleTypeDef htim3;
UART_HandleTypeDef huart4;
/* USER CODE BEGIN PV */
char txtbuff[64];
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
static void MX_ADC_Init(void);
static void MX_TIM3_Init(void);
static void MX_USART4_UART_Init(void);
/* USER CODE BEGIN PFP */
uint16_t readv1(void);
void readv1(uint16_t);
void readv2(uint16_t);
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
    uint16_t volt1;
        volt1 = readv1();
        readv2(volt1);
        readv3(volt1);
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  MX_GPIO_Init();
  MX_ADC_Init();
  MX_TIM3_Init();
  /* Infinite loop */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSI14;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSI14State = RCC_HSI14_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.HSI14CalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  hadc.Init.ContinuousConvMode = DISABLE;
    Error_Handler();
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
/* USART4 init function */
  huart4.Instance = USART4;
  huart4.Init.BaudRate = 57600;
  huart4.Init.WordLength = UART_WORDLENGTH_8B;
  huart4.Init.StopBits = UART_STOPBITS_1;
  huart4.Init.Parity = UART_PARITY_NONE;
  huart4.Init.Mode = UART_MODE_TX_RX;
  huart4.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart4.Init.OverSampling = UART_OVERSAMPLING_16;
  huart4.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart4.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart4) != HAL_OK)
    Error_Handler();
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOE, GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_0, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_14|GPIO_PIN_15|GPIO_PIN_7|GPIO_PIN_8
                          |GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOF, GPIO_PIN_9, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_9, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11
                          |GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_0|GPIO_PIN_1
                          |GPIO_PIN_3|GPIO_PIN_4, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_8|GPIO_PIN_15, GPIO_PIN_RESET);
  /*Configure GPIO pin : PE2 */
  GPIO_InitStruct.Pin = GPIO_PIN_2;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : PE3 PE4 PE0 */
  GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  /*Configure GPIO pins : PC14 PC15 PC7 PC8
                           PC9 PC10 PC11 PC12 */
  GPIO_InitStruct.Pin = GPIO_PIN_14|GPIO_PIN_15|GPIO_PIN_7|GPIO_PIN_8
                          |GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pin : PF9 */
  GPIO_InitStruct.Pin = GPIO_PIN_9;
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  /*Configure GPIO pins : PB12 PB13 PB14 PB9 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_9;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  /*Configure GPIO pins : PD8 PD9 PD10 PD11
                           PD12 PD13 PD0 PD1
                           PD3 PD4 */
  GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11
                          |GPIO_PIN_3|GPIO_PIN_4;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : PA8 PA15 */
  GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_15;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
    //char txtbuff[64];
    chConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
    HAL_ADCEx_Calibration_Start(&hadc);
    uint32_t v = HAL_ADC_GetValue(&hadc);
    uint16_t vm = (uint16_t) v;
    sprintf(txtbuff, "%u\n", vm);
    return vm;
void readv2(uint16_t volt1){
    //Here I try to read ADC_CHANNEL_2
    //char txtbuff[64];
    chConfig.Channel = ADC_CHANNEL_2;
    uint16_t vm = ((uint16_t) v / volt1)*3300;
void readv3(uint16_t volt1){
    //Here I try to read ADC_CHANNEL_4
    //char txtbuff[64];
    chConfig.Channel = ADC_CHANNEL_4;
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
  • \$\begingroup\$ In your 1st code snippet, you're not actually performing an A2D conversion - so not reality surprising you're seeing the same value. The 2nd snippet looks like it would do the job. \$\endgroup\$ – brhans Apr 14 '17 at 9:08
  • \$\begingroup\$ readv2(volt1)? You're passing what argument exactly? \$\endgroup\$ – ammar.cma Apr 14 '17 at 9:14
  • \$\begingroup\$ @brhans He does not have to start and stop a conversion; he is using continuous conversion mode. So whenever he pulls Get_value ; he should get it in theory. \$\endgroup\$ – ammar.cma Apr 14 '17 at 9:16
  • \$\begingroup\$ @ammar.cma, I'm passing uint16_t volt1 which is a reference value measured by volt1 = readv1();. \$\endgroup\$ – Marco Apr 14 '17 at 9:17
  • \$\begingroup\$ @ammar.cma whenever the code executes HAL_ADC_GetValue(&hadc); it should get the value, but how can I tell from which ADC channel it is taking it? \$\endgroup\$ – Marco Apr 14 '17 at 9:20
In the last update I posted I was trying to read the ADC channels in polling mode but what I actually needed was to read the ADC in interrupt mode.
Finally, I solved the problem by modifying the functions as follows (I show for readv1 function):
    // Then I replaced the HAL_ADC_Start(&hadc); instruction by the following one:
    // This starts the ADC in interrupt mode
    // I deleted the HAL_ADC_PollForConversion(&hadc, 0xFFFFFFFF); instruction as I'm not using polling working mode
    // I replaced the HAL_ADC_Stop(&hadc); instruction by the following one:
    HAL_ADC_Stop_IT(&hadc);
    // This stops the ADC working in interrupt mode
    sprintf(TextBuffer, "%u\n", vm);
    return vm;
I did the same modifications in readv2 and readv3 functions. Actually, as I'm using the same procedure for reading all the ADC channels I created a function which receives as parameter the channel number.
