Zigbee Light Link is a subset of Zigbee Home Automation. My question is : is it possible to add a device with ZLL profile to a Zigbee Home Automation Network?
UPDATE I have a ZLL based device in the form of Mesh Bee, When I query available networks through the AT command it lists the Mesh Bee that has been set as a coordinator.
I have another device that is using Home Automation Profile and is a coordinator, But it doesn't get listed in the list of available networks!
Yes. That's kinda the whole point behind ZLL.
Update to Update: That's why I don't use third party APIs. When something goes wrong it's not worth the effort to figure out someone else's code to fix the bug.
  • \$\begingroup\$ great, I have updated my question. If this is the case I am not able to get a HA profile coordinator in list of available networks! what could be wrong with this! \$\endgroup\$
    – dmSherazi
    Commented May 9, 2017 at 11:03
  • \$\begingroup\$ Thanks . I have one more question ... If a system is using standard HA profile, would I be able to join any HA profile device to it ? \$\endgroup\$
    – dmSherazi
    Commented May 10, 2017 at 11:51
