I am currently working on a project that involves designing some front end electronics that shape the charge pulse from a solid state detector (effectively a current source - I1 on the diagram). Our source produces a pulse that is about 10us long. The design is essentially a charge sensitive preamplifier, followed by pole zero, followed by two Sallen-Key filters in a low pass configuration that act as shaping. I have a circuit schematic that works, however I should like the outcoming voltage pulse over the load (R13) to be longer. Currently, the pulse is semi-gaussian and lasts for about 200-300us. If I could double or triple this time it would work better with the readout electronics. I would also be interested to know if what i have done is correct, as I don't have a background in electronics so there may be bare faced errors in the design.
On final question on this topic is this - what is the best way to increase the height of the voltage pulse, while keeping the noise to a minimum? I can do this by changing R9 or R10, however I am wondering if there is a better way to do this.
