I need help understanding what these ratings mean. This is a general purpose relay. I'm confused. The Turn on/Off voltages are these voltages that need to be provided to the relay to turn the relay on and off? Is the Coil voltage the voltage that I can safely switch on this relay? Is the Contact Rating Current the current that this relay can handle?
Coil Current 4.5mA
Coil Voltage 48VDC
Turn On Voltage (Max) 33.6 VDC
Turn Off Voltage (Min) 2.4 VDC
Contact Rating (Current) 6A
Switching Voltage 400VAC - Max
