I've been trying to decipher the many numbers on the top picture, and it just doesn't make sense to me.
Why would you need a hole of size 1.19 mm when the pins are only 0.45x0.58 mm? This leads me to believe that 1.19 mm is the size of the pad, but then how big should my hole be?
I made the pin holes 0.762 mm. That should work right? What about the mounts on either side? Because, if I'm following the logic I used to discern that the first number next to a hole is the size of the pad, then I'm still left without a size for the hole. Nowhere else on the datasheet do they say how large the mounting pins are.
