Is it possible to use one battery pack as this one (LINK) to power one RGB LED stripe (12v) + 1 raspberry pi (via a voltage regulator like this) + 1 micro servo SG90 (THIS) ??
What would be the perfect diagram? LED straight to the battery, then step down circuit then servo and rpi in parallel? Would I need two step down circuits to ensure that peak consumption in the servo does not reboot my raspi?
Will the battery be able to provide enough mAh for the three things ?
