In a text it mentions about a power supply that the filter cap will act as a short at initial turn-on. Below I showed these points as A and B:
In this case, the diode will have a surge current Is. And the text says this Is current should be limited by a resistor between the transformer and each diode.
But in practice isn't transform's winding enough to limit this current? What is the typical value for this resistor lets say for a 24V power supply? Im asking because I dont see any such series resistors in examples. Im wondering is it fine to neglect it.
