Quite often we "combine" several signals, send them over a single wire or fiber or through the air, as a single combined signal, and at the far end separate them back into more-or-less the original signals.
There are dozens of different ways we "combine" signals.
Then, is it possible to figure out the frequency content ... using any kind of transform?
We almost always use a fast Fourier transform to figure out the frequency content of a signal.
(A few people are experimenting with other techniques for finding the frequency content of a signals -- the Hartley transform, the fast Walsh–Hadamard transform, the chirplet transform, wavelet transforms, etc.)
Suppose that we take finite samples of these signals. (so, finite time
of transform.)
In practice, whenever we sample a signal, we always take a finite number of samples of a signal, over some extremely limited amount of time.
We must already know (or guess) at the frequency range of interest in order to select the proper anti-aliasing filter and sample rate.
Then, is it possible to figure out the frequency content of the two
original signals using any kind of transform?
You must know something about how the signals were combined, and something about the original signals, in order to get any useful information out of the combined signal.
For example, say you know that the original signals were audio in the human hearing range,
and the first signal was AM modulated to 540 kHz, while the second signal was AM modulated to 1610 kHz, and then the two modulated signals were added together.
In that case it's pretty easy to figure out the frequency content of each of the two original audio signals, looking at the display of a RF spectrum analyzer
(which is often implemented by taking a finite number of samples and then applying a fast Fourier transform).
It's also pretty easy to demodulate and recover signal A and signal B that are more-or-less the same as the original first signal and second signal, respectively.
For another example, say you know that the original signals were audio in the human hearing range, and they were AM modulated and then the modulated signals were added together, but you don't know ahead of time what particular modulation frequency was used.
In that case it's pretty easy to look at the display of a RF spectrum analyzer and figure out what modulation frequencies were used.
Then you can tell if the modulation frequencies are far enough apart,
and if so, you can demodulate and recover signal A and signal B that are more-or-less the same as the original first signal and second signal; and figure out the frequency content of signal A and signal B -- but it's impossible to tell if the first signal goes with signal A and the second signal goes with signal B, or vice-versa.
On the other hand, if all you know is that the original signals were audio in the human hearing range, and then they were simply added together,
(or if each one was AM modulated to approximately the same frequency and then added),
it's pretty much impossible to separate them.
You can figure out the frequency content of the combined signal,
by looking at the spectrum -- the Fourier transform of the combined signal.
If you are lucky, and the signals were not synchronized with each other,
you can figure out some information about the frequency content of the two original signals.
When you see "quiet" frequencies in the combined signal,
both the first and the second signal must be quiet at that frequency.
When you see "loud" frequencies in the combined signal,
either the first or the second signal must be producing that frequency.
But without more information, it's impossible to tell if that "loud" frequency is only being produced by the first signal, or only by the second signal, or by both the first and second signals.
