R2=100 ohm , R3=150ohm , R4=220ohm , R6=330ohm
I calculate equivalent resistance like this
150*100/150+100=60 ohm
220*330/220+330=132 ohm
60+132=192 ohm
can you tell me whether it true or wrong?
  • \$\begingroup\$ R3 is not parallel with R2. R3 is in parallel with R2+(R4||R6) \$\endgroup\$
    – G36
    Commented Feb 17, 2018 at 12:25
    \$\begingroup\$ As seen from source terminals? In that case it'd be R3 || (R2 + (R4 || R6)) \$\endgroup\$
    – Deep
    Commented Feb 17, 2018 at 12:29
This only looks difficult because of the layout. If you would take the time to redraw it you could see that this is very simple to solve.
R4 and R6 are in paralell, so calculate it first. Then, do the series with R2, and finally, the paralell with R3. So:
1/Ra = 1/R4 + 1/R6
Ra = (R4*R6)/(R4 + R6)
Rb = Ra + R2
Rtotal = (Rb*R3)/(Rb + R3)
