I am trying to embed code in my Attiny4 project that will set fuses and lock bits(In AtmelStudio 7). I copy/pasted the code that Atmel suggests here:
#include <avr/io.h>
typedef struct _tagConfig
    unsigned char f1;
} Config;
typedef struct _tagLock
    unsigned char f1;
} Lock;
typedef struct _tagSig
    unsigned char f1;
    unsigned char f2;
    unsigned char f3;
} Signature;
Config __config __attribute__((section(".config"))) =
    f1 : 0xfb, // Set CKOUT
Lock __lock __attribute__((section(".lock"))) =
    f1 : 0xfc, // Further programming and verification disabled
Signature __sig __attribute__((section(".signature"))) =
    f1 : 0x03,
    f2 : 0x90,
    f3 : 0x1e,
Then i try to compile and it directly fails with the following errors:
attiny4-fan.elf section `.config' will not fit in region `config'
region `config' overflowed by 1 bytes
ld returned 1 exit status
recipe for target 'attiny4-fan.elf' failed
I can't seem to find any other information on how to do this for an ATTiny4/5/9/10. The Datasheet seems to mention something about the locations but since i have never done this before, especially not for the Attiny4 i'm playing with here, i have no idea on how to proceed.
Attiny4/5/9/10 Datasheet
This is the output of
avr-objdump --section-headers
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .text         000000c8  00000000  00000000  00000074  2**1
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  1 .data         00000000  00800040  00800040  0000013c  2**0
                  CONTENTS, ALLOC, LOAD, DATA
  2 .bss          00000003  00800040  00800040  0000013c  2**0
                  ALLOC
  3 .comment      00000030  00000000  00000000  0000013c  2**0
                  CONTENTS, READONLY
  4 .note.gnu.avr.deviceinfo 0000003c  00000000  00000000  0000016c  2**2
                  CONTENTS, READONLY
  5 .debug_info   000002ab  00000000  00000000  000001a8  2**0
                  CONTENTS, READONLY, DEBUGGING
  6 .debug_abbrev 00000284  00000000  00000000  00000453  2**0
  7 .debug_line   000000d3  00000000  00000000  000006d7  2**0
  8 .debug_str    000000f6  00000000  00000000  000007aa  2**0
In the mean time, i also found out that in the ATtiny DFP header file for the Attiny4/5/9/10, the following macros are defined(ATtiny9 as example):
/* Fuses */
#define FUSE_MEMORY_SIZE 0
/* Lock Bits */
#define __LOCK_BITS_EXIST
/* Signature */
#define SIGNATURE_0 0x1E
#define SIGNATURE_1 0x90
#define SIGNATURE_2 0x08
Why would FUSE_MEMORY_SIZE be defined as 0?
Can anybody help me to get my ELF to contain fuses and lock bits?
  • \$\begingroup\$ Can you compile your project to .o files and use objdump --section-headers to see if you have any other sections that match .config* in there? Looking through the linker script, any such sections would be concatenated into the space, which obviously isn't going to work... \$\endgroup\$
    – Jules
    Commented Feb 27, 2018 at 16:45
  • \$\begingroup\$ How would i do that? I'm on Windows 10. I have no other sections in the code where i try to modify these sections. \$\endgroup\$ Commented Feb 27, 2018 at 17:08
  • \$\begingroup\$ I would expect the program to have been installed in the atmel studio's toolchain directory, but unfortunately I don't have it installed on this machine at the moment, so can't check. \$\endgroup\$
    – Jules
    Commented Feb 27, 2018 at 18:34
  • \$\begingroup\$ So i googled a bit and found an .lss file. It contains a commented header that mentions .text, .data, .bss, .comment and other sections. Could that be what you were looking for? I can't find anything .config related there \$\endgroup\$ Commented Feb 27, 2018 at 18:48
  • \$\begingroup\$ You were absolutely right, it's installed in the toolchain directory, i found the file and was able to run the command. The output is the same as the one i found in the .lss file, will append it to the original question. \$\endgroup\$ Commented Feb 27, 2018 at 19:31
