I am trying to understand ANC practical implementation from a headset in which ANC has been implemented. The microphone which senses the noise has three terminal. I have only seen microphone which has two terminal (one for power and signal other one for ground). The image attached below is a microphone marked as A. I am unable to understand, what is B. What is the use of B in picking up the noise.
The second image shows back portion of the PCB. It has three terminals, one should be for power and signal other one should be for ground. What is the third wire doing here.
Image 1 Image 2
  • \$\begingroup\$ B looks like a conductive gasket ... it probably presses against another grounding contact when the enclosure is closed \$\endgroup\$
    – jsotola
    Commented Mar 5, 2018 at 18:06
  • \$\begingroup\$ 3 wires ... it is either a stereo microphone, or the ground wire is just a shield \$\endgroup\$
    – jsotola
    Commented Mar 5, 2018 at 18:08
  • \$\begingroup\$ Hi jsotola, what is the functional use of conductive gasket. \$\endgroup\$
    – TapasX
    Commented Mar 5, 2018 at 18:10
  • \$\begingroup\$ Yes, it presses against another enclosure, which is metal. \$\endgroup\$
    – TapasX
    Commented Mar 5, 2018 at 18:20
  • \$\begingroup\$ Does it contain ferrite? A is a dual piezo differential FET buffered mic with Vdc in and AC +DC bias voltage out \$\endgroup\$
    – D.A.S.
    Commented Mar 5, 2018 at 18:21
The thing you have marked A could indeed be a three terminal electret microphone. One lead supplies power, one is ground, and the other is the signal.
Three terminal mono electret microphones are not uncommon.. That link goes to an example (picked at random) Knowles microphone on Digikey.
Given the form of the microphone, it might also be a MEMs microphone. MEMs microphones are often SMD parts. They also come in versions that have a digital ouput (they digitize the audio with a built in ADC.) Whether digital or analog, MEMs microphones usually have the output separate from the power.
I don't think you will learn much of direct use by looking at the hardware. The magic bit that makes it work is either electronic (very simple cancellation) or in software (more advanced and effective types of cancellation.)
You would probably learn more by reading papers on noise cancellation techniques and alogorithms.
The silvery thing (marked B) is probably for connecting the circuit ground to a metal (or at least conductive) part of the housing. This is to minimize the electrical noise (like radio and cellphone or from other electronic devices) that the wiring for the microphone picks up.
It is in the form of a soft pad rather than something harder so that it doesn't mechanically transfer vibrations on the housing to the PCB with the microphone.
