De Morgan
$$y=\overline{a+\overline{b(\overline{c+d})}}+\bar{b}$$ $$y=\bar{a}(\overline{\overline{b(\overline{c+d})}})+\bar{b}$$ $$y=\bar{a}(b(\overline{c+d}))+\bar{b}$$ $$y=\bar{a}(b\overline{cd})+\bar{b}$$ $$y=\bar{a}b\overline{cd}+\bar{b}$$
This is as far as I've got on my simplification:
$$x+\bar{x}y=1+0\cdot1~or~0+1\cdot1$$
So it might be
$$1+0~or~0+1=1$$
But
$$\bar{a}b\overline{cd}+\bar{b}=\overline{acd}(b+\bar{b})=\overline{acd}\cdot 1=\overline{ac}d$$
I can't understand why it's will be \$y=\overline{acd}+b\$, so how I must to minimize this \$b\$?
Maybe I solved it! a'bc'd'+b'= (a+b'+c+d)'+b'= ((a+b'+c+d)b)'= (ab+b'b+cb+db)'= (ab+1+cb+db)'= ((a+c+d)b)'= (a+c+d)'+b'= =a'c'd'+b' Is it correct?
  • \$\begingroup\$ Ok thank you for editing your problem. Now I need a little clarification. What do you mean by your last sentence, "I can't [understand] why..." I don't understand what you're trying to say nor how you're relating this to your question. \$\endgroup\$
    – user103380
    Commented Jul 2, 2018 at 15:36
  • \$\begingroup\$ I'm voting to close this question as off-topic because homework needs and attempt at a solution (even if you do have the answer) \$\endgroup\$
    – Voltage Spike
    Commented Jul 2, 2018 at 15:41
  • \$\begingroup\$ @KingDuken the solution of the function should be this y=a'c'd'+b but I don't know how to get it.. I can't undersand how to semplify b+b' so why b it's desaper? Cos for the rule a+a'=1 so it's must be just a'c'd' but in the correct answer of this exercise is a'c'd'+b \$\endgroup\$
    – Ciao
    Commented Jul 2, 2018 at 15:43
  • \$\begingroup\$ @laptop2d A small question. If one has done his homework but can't solve it. What should he do? Do not ask for the explanation of why it's wrong? \$\endgroup\$
    – Ciao
    Commented Jul 2, 2018 at 15:46
  • \$\begingroup\$ You just need the intuitive connection...think about it this way. If b is false, the result will be unconditionally true due to the right term. Therefore, the only time the left term is needed is when b is true. So if the left term will affect the result in any way, it can be assumed that b is true--so it's optimized out with that assumption. \$\endgroup\$ Commented Jul 2, 2018 at 15:49
De Morgan $$y=\overline{a+\overline{b(\overline{c+d})}}+\bar{b}$$ $$y=\bar{a}(b(\overline{c+d}))+\bar{b}$$ You are correct up to this point. Based on the comments, you are correct for the rest, but you fooled up the mathjax syntax as you deMorganed. Corrected we have: $$y=\bar{a}b\bar c \bar d+\bar{b}$$
You are also headed in the correct direction: $$X+\bar{X} Y = X + Y$$
Which is the redundancy law. The inclusion of \$X\$ means the \$\bar X\$ in \$\bar X Y\$ is redundant.
  • \$\begingroup\$ Yes cos x(y+y') + y(x+x')=x+y \$\endgroup\$
    – Ciao
    Commented Jul 6, 2018 at 22:25
