9
ever since posting here I never been so lost of using op-amps before, hearing new things that I have never heard before (Vom, Vcm etc). I always thought OP AMPS is just plug it in and it will work everytime... Very wrong.
I have a couple of questions which would be most appreciated if anyone of you could answer them, before I asked them, yes I have been looking for the past 2 hours in this forums for previous questions that were asked. Still a little confused but it did clear some things up.
To keep things consistent I would be using This OP AMP throughout this whole example. MCP601
VCM: Common Mode Input Range
Here is what I understand -Its the range of which the MCP601 can happily accept with nothing going wrong, if one were to go over or under these ranges the op you will see unexpected error.
Example: Input = Audio Signal (1.2V pk-pk) VDD = 4.8V VSS = GND enter image description here
VCM - Upper limit = 4.8-1.2 = 3.6
VCM - Lower limit = 0-0.3 = -0.3
VCM - \$V_{CM_{PP}}\$ = 3.6-(-0.3) = 3.9V
\$V_{IN}\$ - Positive Cycle of input = 600mV + (VDD/2) = 3
\$V_{IN}\$ - Negative Cycle of input = -600mV + (VDD/2) = 1.8
\$V_{IN}\$ = 1.2Vpk-pk
Meaning the input Vpk-pk is suitable?
VOM: Output Voltage Swing
Here is what I understand - Its the range of which the MCP601 is capable of outputting before clipping.
Example: Input = Audio Signal (1.2V pk-pk) VDD = 4.8V VSS = GND GAIN = 3.2
Input Bias = VDD/2 RL = 5k
VOM - Upper limit = 0+100mV = 100mV
VOM - Lower limit = 4.8-100mV = 4.7V
VOM - \$V_{OM_{PP}}\$ = 4.7-100mV = 4.6V
\$V_o\$ - Positive Cycle of input = (3.2*600mV)+(VDD/2) = 4.32V
\$V_o\$ - Negative Cycle of input = (3.2*-600mV)+(VDD/2) = 0.48V
\$V_o\$ - \$V_{o_{PP}}\$ = (4.32-0.48) = 3.84V (Before decoupling Cap).
This is how I understood to calculate for both \$V_{CM}\$ and \$V_{OM}\$. To me this OP-AMP shouldn't have a problem with the Vin as well as happily amplifying the Vin as well, however the opposite happened as it clips at 2.84Vpp. This doesn't make much sense to me from the calculation above. The VCM should be satisfied as well as the VOM. As the VOM has a Vpp of 4.6V which is > then my Vo of ideally 3.84Vpp and my VDD being 4.8V it should amplify to 3.84Vpp no problem?
If anyone can show me how to actually calculate VCM and VOM that would be amazing, I believe this method is missing something or I am not understanding some fundamental logic. I would like to gain the ability to understand input and output limitations through this method.
This configuration works if I increase VDD to ~6.1V if anyone can explain why through the VCM and VOM calculations I can probably correlate the two and probably will clear up any confusions I had.
    \$\begingroup\$ +1 on the question. By the way, I think you should spend time studying the schematic of a BJT diff-pair input opamp. It will help a great deal. You will much better understand common-mode input range and also the output. Suddenly, you will "see" when you examine one closely. Staying "distant" will prevent you from "seeing" clearly and instead just give you a bunch of "rules of thumb." Looking over a specific opamp design will tell you so much more and allow you to think for yourself on these questions. \$\endgroup\$
    – jonk
    Jul 11, 2018 at 4:30
  • \$\begingroup\$ I appreciate the 1-up! I 100% agree with you, I wish schools taught this characteristic of the op-amps. I feel like I am not doing the question and justice. The number of times my op-amp doesnt work due to input and output limitations is just gets annoying and it isnt an easy thing to search on the internet as well... \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 4:34
  • \$\begingroup\$ Try looking over some existing questions: (1) Current Paths, AB amplifier, and LM380. All three of those deal with the LM380. The first thing to understand is the input stage's differential-amp "pair". Follow that and the common mode part is easy. \$\endgroup\$
    – jonk
    Jul 11, 2018 at 4:46
    \$\begingroup\$ Whenever someone asks about opamps and how to use them, I suggest reading "Opamps for everyone", it's a free ebook: web.mit.edu/6.101/www/reference/op_amps_everyone.pdf \$\endgroup\$ Jul 11, 2018 at 6:31
  • \$\begingroup\$ I ran thru this many times, I agree its an amazing ebook as it did clear somethings up, however it doesn't answer some of my specific questions. For example it doesnt really tell you how to check for output voltage swing, instead it tells you if the datasheet specifies a RL = 50 it can drive more things than RL = 25k \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 6:42
Your 2nd datasheet snip is in mV not volts, and the output range is relative to the supply voltages. So with a 4.8V supply and 5K load (to 0V) the linear output range is 0.1 to 4.7V. If you bias the input and output at 2.4V you can get 4.6Vp-p. The op-amp output cannot exceed (or even meet) the supply voltages.
If the input is biased at 2.4V, your input range is -0.3 to 3.6V so you can only handle an input voltage of 2.4Vp-p = (3.6-2.4V)*2, based on the input range, however you also need to make sure the output does not saturate.
Your circuit has a gain of +3.2 so input voltage has to be within the range of +/-0.71875V or 1.4375Vp-p, which will yield the full output range, so the input range is not limiting.
You can use pretty much any op-amp on a single power supply provided you have enough supply voltage and provided you bias the input within the working range and provided you keep in mind the available output range.
In general for a low power circuit you would want to use higher value resistors than you show. You are loading the output with 5K||(2.2K+1K) which is lower than 5K, obviously, so the output swing is not guaranteed. Normally you can go at least 10x higher for the feedback resistors, maybe considerably more. If you can increase the load to 25K or 100K, and increase the feedback resistors by 100:1 it would be better. You may have to add a small capacitor across R3 to assure stability if you go very high with the resistors.
    \$\begingroup\$ Sorry about that completely missed the mV, fixed it. Sorry, once again :/ I dont understand how you came to 2.4Vp-p for some reason it makes sense that my input is 1.2Vp-p as its shown above, did I make a mistake in the calculations? \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 3:22
  • \$\begingroup\$ Your output will saturate before the input causes trouble but with the input biased at 2.4V you can go down to below 0V but on the high side you can only go to 3.6V so that is the limiting number (through the capacitor it will be centered at 2.4V) 3.6V - 2.4V is 1.2V. So +1.2V relative to 2.4V. The input can go negative (relative to 2.4V by more than 2.4V but that doesn't matter). Anyway, the input is not limiting, the output is limiting with a gain of 3.2, and mid-supply (2.4V in this case) is the optimal bias because the output range is centered around the middle of the supply voltage. \$\endgroup\$ Jul 11, 2018 at 3:27
  • \$\begingroup\$ I still don't understand the output is limited, based on the calculations Vom: -0.1V < Vo < 4.7V Vo: 0.48 < Vo < 4.32V this is at the output of the op amp, unless when you decouple it thats the problem? \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 3:36
  • \$\begingroup\$ The linear output range with a 4.8V supply is +0.1V to +4.7V with a specified load of 5K. It would be better to have a load of 25K or more. Your load is less than 5K so output swing may be less than specified. \$\endgroup\$ Jul 11, 2018 at 3:40
  • \$\begingroup\$ I have tried using a 1M and it still clips? \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 3:43
I believe I figured out the conundrum.
Taking up a project such as this and using op-amps to this extent, such as looking for characteristics you wouldn't usually look for coming out of university as input bias current, Vom, Vcm, etc.
Trying to joggle all these terms tend to confuse me and kinda overwrite the basic things I knew about op-amps.
When I was first introduced \$V_{OM}\$ and \$V_{CM}\$ for some reason I made myself believe as if the \$V_{in}\$ and \$V_{out}\$ didn't violate the \$V_{OM}\$ and \$V_{CM}\$ then clipping shouldn't exist. THIS IS completely WRONG
What I didn't account for is the voltage drop that the op-amp has internally due to it's architecture of the op-amp.
Meaning no op-amp can go rail-to-rail unless its perfect (no voltage drop in the internals).
For the problem above is a single power supply non-inverting amplifier, which means it requires a bias in order to swing "negative"
For Reference:
thus, its 4.576V -- 2.288V -- 0V
\$V_{DD_{pp}}\$ = 4.576V \$V_{DD_{p}}\$ = 2.288V
Through experiments, I found the voltage drop of the amplifier to be around ~1.616Vpp
We will do 2 case scenarios Where,
input_1 = 860mVpp
Input_2 = 1.14Vpp
Gain = 3.2
Input_1: 860mVpp
VCM:
-0.3 < \$V_{IN}\$ < 3.376
Vin:
1.858 < \$V_{IN}\$ < 2.718
Vin is within range of Vcm
VOM:
-15.424 < \$V_{OUT}\$ < 15
0.912 < \$V_{OUT}\$ < 3.664
Vo is within range of Vcm
You would expect your signal to behave as you predicted.
Input_2: 1.14Vpp
VCM:
Vin:
1.658 < \$V_{IN}\$ < 2.798
VOM:
0.404 < \$V_{OUT}\$ < 4.052
You would expect your signal to behave as you predicted, however it isn't.
On my oscilloscope it clips at 2.96Vpp but we expected the output to be 1.14Vpp * 3.2 = 3.648Vpp? What is happening is the Voltage drop of the op-amp.
As mentioned above the voltage drop of the op-amp was ~1.616Vpp so doing the math in-tales
VDD -Vod = 4.576 - 1.616 = 2.96Vpp !! This essentially is telling us what our op-amp can actually drive up to. Which all makes sense now.
Essentially what an op-amp says rail - to - rail it means at least what I can see is that your Vin and Vout will never usually violate the op-amps VOM and VCM's
This is why when I increase VDD ~6.1V it works as the op amp can actually drive up to the expected output of 3.648Vpp as follow:
Vdd - Vod = 6.1 - 1.616 = 4.484 as the op-amp new limit is now 4.484Vpp and since 3.648Vpp < 4.484Vpp you can see it on the output.
Vpk-pk = 3.6-(-0.3) = 3.9V.
Possibly. The mid point of CM range is not Vdd/2 here but 3.9/2=1.95V. This would then permit an input signal up to 3.9Vpp. . However your gain would clip the output.
The output stays in the linear range if the output is not clipping. It is defined for symmetrical clipping @100mV from both supply rails depending on loads >5k connected to VL=2.5V. This is because CMOS rail-to-rail Op Amps have a resistance at clipping on the order of 250 Ohms on either Nch or Pch driver. If the load goes to Vss=0 then there is less dropout above Vss but more dropout below Vdd as there is now twice the current compared to spec with [email protected]
Vin{pp}*Av=1.2*2.4=3.84Vpp will fit in the linear output range when the input and difference reference are both common (zero differential) near the middle of the CM range. (Remember near 2V for your supply) It also works for Vdd/2=Vcm bias in this example.
Advice: use R min values of 25k for feedback and load combined
All Op Amps output resistance is lowered by negative feedback gain. But clipping results in total loss of negative feedback. Since FET rise in RdsOn when Vgs reduces which here is Vdd , it is known to rise rapidly below 5V just like CD4000 family logic towards 1kOhm and higher at Vdd min.
  • \$\begingroup\$ I believe I am starting to understand what you're saying. You're suggesting its due to my RL value as its not actually 5k but less than it therefor bringing my headroom much less. \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 4:28
  • \$\begingroup\$ I forgot to mention when increasing VDD to ~6.1V it fixes everything \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 4:38
  • \$\begingroup\$ Also forgot to mention, Changing the resistor feedback wont be viable as I am using a digi pot as R2 so learning how to read VCM and VOM will be more viable as I probably need a new OP AMP \$\endgroup\$
    – Leoc
    Jul 11, 2018 at 4:45
