I am a little confused regarding the order of bytes that are transferred through SPI to a slave device.
The next time diagram depicts the sequence of bytes to be sent when we want to write data to a a flash memory chip
After I send the command byte (first 8 byte to the slave device (Flash Memory) I must send the address bytes and then the data I want to write.
So my question is this: Which byte do I send first, after the command byte? The High Byte or the Low byte of the address? Although it doesn't make sense to me why the High Byte should be sent first it is obvious in the diagram that the High Byte must be sent first and then the Low Byte. So, I wanted to ask in case I am thinking it the wrong way.
Thank you for your time
