I'm trying to select a DC-DC voltage inverter/regulator which can take a 5V USB input and output -5V for use as Op-Amp power supplies.
I've identified 2 potential candidates:
  1. TI's LT1054
  2. Linear's LTC1983-5
As far as I can tell the main difference between the two is the switching frequency (~25kHz for the LT1054, ~900kHz for the LTC1983). I did a little research and supposedly the higher the switching frequency the more stable the output voltage is, or the smaller the output capacitance needs to be to maintain the same output stability.
I would prefer to have just one charge pump to power 4 op-amps (3 IC's, one is a dual package). The op-amps are:
  1. Micrel's LMC7101 (2x)
  2. National Semiconductor's LMH6612 dual op-amp (using both amps)
The LMC7101's are being used as nearly constant voltage level buffers and the LMH6612's are being used to buffer signals (anywhere from close to DC up to a few MHz). Looking over the datasheets the LMH7101's have a supply current of at most 1.7mA and the LMH6612's have a supply current of at most 4.85mA per channel. This means I should be drawing at most 13.1mA to power these chips.
As far as cost goes, the LTC1983-5 is $4.28 and the LT1054 is $2.87 through Digikey. However, the LT1054 example schematics use 100uF caps, which are significantly more expensive than the 10uF caps used by the LTC1983-5 especially for high-quality low ESR ones. The LT1054 also requires larger input capacitors.
Is my analysis here correct? What other parameters should I take into account? And most importantly why should I pick one over the other (for reasons other than cost, if any)? Are there any other recommendations for other solutions I should look into for providing the +/- 5V Op-amp supplies? I am limited to the 5V input from USB.
Beside your reasoning, remember that the current consumption you mentioned for the opamps represents the current drawn at no load, so you should also count the loads, as well (if they do count). Then see if the two ICs can suply this much power as the datasheets specify 100mA max. In addition, LT's IC seems to have a far better quiescent current and, as you said, the external parts are cheaper. As for other parameters to count, load behaviour, temperature, humidity, if they count, out of which the first may be the more important. My guess: go with LT, same results, different prices.
  • \$\begingroup\$ (I don't see "add comment" beneath Ben's reply) That can be avoided by a simple 1Ohm resistor in series witht he ICs supply. The drop at 100mA will be 100mV, and the current limiting would also be accounted for by the wirings and traces. Still, USB powered devices have been for a while and quite a few use capacitors for decoupling or such and they work. This is not to say that it "can't" happen, true. \$\endgroup\$
    – Vlad
    Commented Aug 29, 2012 at 7:21
Neither of those is going to work without an external current limiter.
Because your device is USB powered, you need regulators/inverters with soft-start capability, or else you will exceed the inrush limits on USB. Having excessive capacitance on VBUS implies that you'll fail logo certification, and some USB host adapters will detect excessive current and kill power to your device.
  • \$\begingroup\$ I have a soft-start circuit for the device. I just need access to a +/- 5V. \$\endgroup\$ Commented Aug 31, 2012 at 22:36
