I want to glue a piezo plate looking like in the image below such that the wide surface of the plate gets glued onto a flat surface. The image is part of the datasheet from here.
If I apply an AC voltage to the piezo plate such that it starts expanding and contracting along the flat surface it's sitting on, will the plate fall off?
I have no actual experience with piezo and wanted to see if gluing a thin piezo plate on a flat surface and have it expand parallel to the surface it's sitting on is feasible. The 2nd image below is what I want to achieve and I was wondering if it really does happen without changing the height (if it really does only move laterally)
(the 2nd image is from here)
  • \$\begingroup\$ That's more of a mechanical engineering question then an electrical engineering question, isn't it? \$\endgroup\$ Commented Aug 17, 2018 at 14:14
  • \$\begingroup\$ @MarcusMüller My apologies, I just edited my question. It may still be a mechanical engineering question but I guess now I'm asking how a piezoelectric shear actuator does move sideways without changing its height \$\endgroup\$
    – Blackwidow
    Commented Aug 17, 2018 at 14:16
  • \$\begingroup\$ a) these dimensions aren't to scale; nothing says it doesn't change its height in here (probably just insignificantly). b) Piezo crystals move by changing their crystal structure periodically; when changing a crystal structure, conservation of volume isn't a given fact. \$\endgroup\$ Commented Aug 17, 2018 at 14:18
  • \$\begingroup\$ @MarcusMüller it wasn't, for which I apologize. \$\endgroup\$
    – Blackwidow
    Commented Aug 17, 2018 at 14:20
  • \$\begingroup\$ no need to apologize! \$\endgroup\$ Commented Aug 17, 2018 at 14:20
You probably need something like a flexible epoxy adhesive
Yes the adhesive should be very low modulus and bond strongly. High modulus and strong bonding would also prevent falling off, but will also clamp the actuation. I have used single component PUR glue in the past which is rubber soft after curing. I suppose this could work well.
