My question surrounds a simple scenario.
I have a 12V DC power source connected to 2.2kΩ/10kΩ/22kΩ resistors in series.
For an assignment, I have theoretically calculated Voltage drops across all resistors, as well as respective current draw for each resistor. I am aware that the current entering a resistor should be the same as coming out.
I have simulated the circuit in Circuit Wizard (Uni assigned software package), and found that after each resistor the current drops fractionally. For example - The Total Circuit resistance is detailed as 350.97microA. Then: Through 2.2kΩ - drops to 350.92MicroA Through 10kΩ - drops to 350.88MicroA Through 22kΩ - drops to 350.86MicroA
Obviously - the difference between my calculated values and the simulated values is only around 0.02%.. However I wouldnt expect the current to change.
When I increase voltage on the power supply - to signifcantly larger values (50V+) - current measurements remain as expected.
Am I right in presuming that this is due to the impedance thats been calibrated into this digital Ammeter? Im drawing conclusions and this is the only thing I can think of.
