I am trying to set GPIO pins to high and low state on an Orange Pi using the following command:
echo 0 > /sys/class/gpio_sw/PA1/data
echo 1 > /sys/class/gpio_sw/PA1/data
This turns the pin on and off.
The /sys/class/gpio_sw/ folder has locations labeled
PA0, PA1, PA10, PA13, PA14, PA2, PA21, PA3, PA6, PA7, PA8, PA9
PC4, PC7
PD14
PG6, PG7, PG8, PG9
Do the prefixes (PA, PC, PD, PG) have any meaning?
Are these all references to GPIO pins?
    \$\begingroup\$ My first thought is it is similar to how Arduino has PORTB, PORTC, and PORTD like in this image: peterbeard.co/postimages/digitalwrite/atmega168-pins.png \$\endgroup\$ Commented Oct 2, 2018 at 15:23
    \$\begingroup\$ @solve that's really how every microcontroller and other ics are, not just arduino \$\endgroup\$
    – Passerby
    Commented Oct 2, 2018 at 19:10
The Allwinner SoCs divide their I/O pins into banks, somewhat like many smaller MCUs do. In some Linux versions these designations are passed through in some cases, in others or at least other contexts they are simply re-numbered, probably starting with 0 for PA0, adding 32 for PB0, etc in order to yield a more usual /sys/class/gpio/gpio0 etc
Ultimately you'll have to consult the references (or source) of your particular operating system flavor, its device tree (if utilized, or legacy configuration if not) your board documentation, and possibly the relevant SoC datasheet.
One resource you probably want to consult is http://linux-sunxi.org/GPIO
