I have to find voltage across R5 using superposition theorem but the problem is that I have a voltage difference of 4.16V,
Circuit
Solution:-
Shorting battery VS1
V<sub>s1</sub> shorted circuit
R34 =8/3Ω =2.67Ω (Solved R3 & R4 in parallel)
R234 =41/3Ω =13.67Ω (Solved R34 & R2 in series)
R1234 =205/56Ω =3.66Ω (Solved R234 & R1 in parallel)
Using Voltage Divider Formula on R5
(1)V5= 6.56V (Voltage when VS1 is shorted)
Shorting Battery VS2
V<sub>S2</sub> shorted circuit
R2345 =287/62Ω =4.62Ω (Solved R234 & R5 in parallel)
Using Voltage Divider Formula on R2345
Therefore, (2)V5=V2345= 2.40V(Voltage when VS2 is shorted)
Since the flow of voltage is opposite on R5 the resultant voltage(V5) can be obtained by taking the difference of the voltages obtained by shorting the batteries.
Resultant V5 =(1)V5 - (2)V5
Resultant V5 = 6.56 - 2.40
Resultant V5 = 4.16V
x------------------------------------------------------------x--------------------------------------------------------------------x
According to my solution after taking the difference at the end I'm obtaining a value of 4.16V of V5 but according to the given answer it says that the answer is 2.40V. I want to know that if there is something wrong with my solution or the answer provided is wrong?.
It seems as though you may need to prove something, given that your answer is correct and apparently a given "correct" answer is actually wrong.
To achieve a counter-proof, it's best to use a series of simple and unarguable transitions of the circuit that lead inevitably to the answer you have. This means using very basic steps, one at a time; steps that anyone can follow and will not be able to argue with:
Assuming you can get whomever the individual is that you need to convince to read this, have them follow along with the above steps:
  1. Replace \$R_3\$ and \$R_4\$ with their parallel equivalent, \$R_X\$.
  2. Replace \$R_X\$ formed in step 1, combined with \$R_2\$, to form a new series equivalent, \$R_Y\$
  3. Redraw the resulting schematic in step 2, into a more readable form. It's the same circuit. Just drawn differently. (Getting rid of distracting wiring often helps to clarify a situation.)
  4. Form the Thevenin source equivalent for the pair of resistors, \$R_1\$ and \$R_Y\$ (formed in steps 1 and 2) to form a new source voltage and source resistance as shown in the final diagram above, \$V_\text{TH}\$ and \$R_\text{TH}\$.
Once you have arrived at step 4, the rest is fairly easy.
$$\begin{align*} I_\text{TOTAL} &=\frac{10\:\text{V}-V_\text{TH}}{R_5+R_\text{TH}}\\\\ V_{R_5}&=I_\text{TOTAL}\cdot R_5\\\\ &=\left(10\:\text{V}-V_\text{TH}\right)\cdot\frac{R_5}{R_5+R_\text{TH}}\\\\ &= 4.16237\approx 4.16\:\text{V} \end{align*}$$
When trying to convince someone, it's better to walk them through a very simple and easy to follow process and to avoid using general, powerful and abstract tools to get there (which may not be as crystal clear in their minds.) Just keep it very basic and I think you will get them to admit their error. It's inescapable.
I do not see any mistake in your solution.
So to check it I will use the nodal analysis and solve for the voltage at the node where R1, R5, and R2 are connected.
$$\frac{V_X}{R_{2}+R_3||R_4} + \frac{V_X - 5V}{R_1} + \frac{V_X - 10V}{R_5} = 0$$
And the solution is:
\$V_X = 5.8375V \$
http://www.wolframalpha.com/input/?i=X%2F(11+%2B+8%2F3)+%2B+(X+-+5)%2F5+%2B+(X+-+10)%2F7+%3D+0
Therefore the voltage across \$R_5\$ is:
\$V_5 = 10V - 5.8375V = 4.16V \$
Which means that your answer is correct indeed.
    \$\begingroup\$ Your answer made me think more and to add my own addition. I liked your approach (I take to nodal like a fish to water) and had you not provided it, I probably would have written similarly and walked away. It was only the juxtaposition of it here that made me realize that they may need to lead a horse to water and make it drink (closest idea might be -- nie można nikogo uszczęśliwiać na siłę, though I gather more literally it is more fully -- możesz doprowadzić konia do wodopoju, ale nie możesz zmusić go żeby się napił.) Nice addition. \$\endgroup\$
    – jonk
    Commented Oct 7, 2018 at 0:27
  • \$\begingroup\$ @jonk How can you know the Polish language? Google translate? \$\endgroup\$
    – G36
    Commented Oct 7, 2018 at 10:05
  • \$\begingroup\$ No. I'm pretty sure google translate couldn't have produced either of those. They are each from Poles who speak Polish. I just know a little about how to look stuff up, is all. \$\endgroup\$
    – jonk
    Commented Oct 7, 2018 at 10:52
