I have a servo drive with 5 digital outputs. I will be connecting one of the outputs to a 24 V relay to disable the drive if a fault occurs within the drive. The manual gives two schematics using sinking and sourcing.
What should I consider when choosing to sink or source? It seems to me that either way will achieve what I am trying to do.
My CNC controller output enables the servo drive using Di1 out of the 8 digital inputs (Di1 to Di8). This is wired according to the sourcing schematic attached.
I have read all the related posts but can't find anything that explains this or simplifies it enough for me to understand.
Here is a link to the manual if required.
I am using the LXM28AU07M3X servo drives.
  • \$\begingroup\$ Gustav. Can you please expand on this "in this case you will have to match the input with the proper PLC output connection" \$\endgroup\$
    – Michael
    Commented Nov 17, 2018 at 15:33
  • \$\begingroup\$ It's still a bit confused. I still reckon that the drive can be disabled internally. What would be worth doing is disabling the other drives if a fault occurs in any one of them so that you don't destroy a workpiece. The answers below answer the question about the relay but I suspect that's not the real problem. There's a CircuitLab schematic button on the editor toolbar. Using the Custom Component on that you can draw a high-level block diagram. Double-click to edit. R to rotate. H and V to flip. \$\endgroup\$
    – Transistor
    Commented Nov 17, 2018 at 15:35
  • \$\begingroup\$ OK. Figure 37 shows how to kill AC power to the drive in the event of a fault. If that's all you need then you can wire the output as source or sink. It just depends whether you would prefer the relay connected to +24 V or ground. Generally connecting the relay negative to ground is less confusing when fault finding. \$\endgroup\$
    – Transistor
    Commented Nov 17, 2018 at 16:04
  • \$\begingroup\$ I have attached another image. Do5 is used to disable the power stage if a fault occurs. \$\endgroup\$
    – Michael
  • \$\begingroup\$ Transistor. Yes that's all I was planning on doing.Great point regarding disabling the other drives if one faults. I will try and impiment this in the design. \$\endgroup\$
    – Michael
    Commented Nov 17, 2018 at 16:54
If you just want to drive a relay, then it doesn't matter if you choose sourcing or sinking, it will work either way, you just need to have 24 V across the relay's coil to make it switch.
Sinking or sourcing matters only if you try to drive some electronic device with a sinking or sourcing input, in this case you will have to match the input with the proper PLC output connection.
Sinking (aka low side switching) will provide higher current with less voltage drop, but sourcing (aka high side switching) will allow the load to have a common negative with the rest of the circuit.
