I have following code in C++
#define NO_SECTORS 4
#define HEADER_SIZE 6
#define SECTOR_SIZE 64
union flash_rec_u{
struct record{
union header_u{
struct header{
uint32_t sector_number;
uint16_t no_written_bytes;
}header_items __attribute__((packed));
uint8_t header_bytes[HEADER_SIZE];
}header;
uint8_t data_bytes[SECTOR_SIZE - HEADER_SIZE];
}rec_items;
uint8_t rec_bytes[SECTOR_SIZE];
typedef uint8_t SECTOR[SECTOR_SIZE];
typedef SECTOR FLASH[NO_SECTORS];
FLASH flash;
SECTOR initialStateSector_00[SECTOR_SIZE] = {
0x01, 0x00, 0x00, 0x00, 0x25, 0x00,
0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
void PrintSector(uint8_t sector){
for(uint8_t curByte = 0; curByte < SECTOR_SIZE; curByte++){
std::cout << std::setw(2);
std::cout << showbase << dec;
std::cout << hex << (uint16_t)flash[sector][curByte] << ", ";
if(curByte % 16 == 15){
std::cout << "\n";
std::cout << "\n";
void PrintFlash(void){
for(uint8_t curSector = 0; curSector < NO_SECTORS; curSector++){
std::cout << "SECTOR: " << (uint16_t)curSector << "\n";
PrintSector(curSector);
void EraseSector(uint16_t sector){
for(uint16_t curByte = 0; curByte < SECTOR_SIZE; curByte++){
flash[sector][curByte] = ERASED_BYTE;
void EraseFlash(void){
for(uint16_t curSector = 0; curSector < NO_SECTORS; curSector++){
EraseSector(curSector);
void WriteBytes2Sector(uint8_t sector, uint8_t *srcBytes){
flash[sector][curByte] = *(srcBytes + curByte);
void ReadSector(uint8_t sector, uint8_t *readBytes, uint16_t noBytes2bRead){
for(uint16_t curSrcByte = 0; curSrcByte < noBytes2bRead; curSrcByte++){
*(readBytes + curSrcByte) = flash[sector][curSrcByte];
void StoreEventLog(uint8_t *eventBytes, uint16_t noEventBytes){
flash_rec_u buffer;
ReadSector(0, buffer.rec_bytes, 1);
std::cout << hex << (uint16_t)(buffer.rec_bytes[curByte]) << ", ";
std::cout << "\n";
std::cout << "\n";
int main(int argc, char** argv) {
uint8_t bytes2bStored[] = {
0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB,
EraseFlash();
PrintFlash();
WriteBytes2Sector(0, *initialStateSector_00);
PrintFlash();
StoreEventLog(bytes2bStored, sizeof(bytes2bStored));
PrintFlash();
return 0;
The flash content after erasing:
SECTOR: 0
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
SECTOR: 0x1
SECTOR: 0x2
SECTOR: 0x3
The flash content after writing into the sector 0:
SECTOR: 0
0x1, 0, 0, 0, 0x25, 0, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa,
0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa,
0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0, 0, 0, 0, 0,
SECTOR: 0x1
SECTOR: 0x2
SECTOR: 0x3
Whenever I call the ReadSector function from the StoreEventLog function for reading content of the sector 0 into temporary variable buffer and then print content of the buffer variable I always get totally wrong content:
0x1, 0xcb, 0xff, 0xff, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0x67, 0x5b, 0x4c, 0xfe, 0x3, 0, 0, 0,
0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0, 0, 0, 0, 0, 0, 0,0,
It seems that the problem is in the ReadSector function, but I don't know where. Could anybody tell me what I do wrong? Thanks for any ideas.
#pragma pack(1)
, which enforces no padding. However, this could cause problems with misaligned access. If skipping padding is no option, then you either have to write serialization/de-serialization routines that puts the data in/out of the struct manually. Or alternatively skip the struct entirely in favour of a rawuint8_t
array. \$\endgroup\$
