I'm new to electronics and working on a hobby project that will have an arduino board running 5 separate strings of RGB LED's. I'll be using a PWM chip (TLC 5940) so I can independently control tho color's of each of the 5 strings of lights. My question is how do I power the LED's. I know they can't be powered from the arduino pins and I highly suspect that they can't be powered from the PWM chip.
I think what I'll have to do is run the PWM output to the base of a transistor and have the string of LED's powered through the transistor with an appropriate power source. Can someone please confirm that and if it is incorrect correct my mistake in layman's terms?
A couple other questions related to this:
1) Is there any "lag" with transistors? i.e. if I run PWM to the base of a transistor will the emitter of the transistor produce an identical source (but amplified)?
2) I saw in an answer to a previous question than I need to look into constant current for the LED's. I still need to do that research but what does a constant current device look like? Is it just an IC you can buy? Can someone provide a part number or link to a page that has one so I can more effectively research how to use them.
